Prodam motor Fiat td 1,9
Prodam dobro ohranjen motor od Fiata Tipo 1,9 td. Motor ima 90 konjev. Zraven motorje je hladilnik olja, interkuler z pripadajočimi cevmi, šterter in altenator. Cena za komplet je 200€.
Tale mašina je dokaj enostavna za vgradit tudi v nivo.
Baje se luknje za nosilce na bloku ujemajo z nivinim blokom. Zvon od nivinega menjalnika pa bi tudi naj pasal.
copy/paste iz difflock foruma:
Both the Fiat 131 and Lada bellhousings DO bolt up to the Fiat diesel block.
The mount holes on the diesel block DO match the standard Niva engine mounts.
The diesel engine is the same length as the Fiat petrol engine block.
No mounts need be made, you can use the Niva ones, sump needs to be modified.
The vacuum pump should be able to be taken off and a diesel alternator with vacuum pump should be able to be mounted, the themostat is on the back of the head so will have to be relocated.
