Tudi na patrolu Y61 2.8 je možno kode napak prebrati brez testerja.
You need to bridge the 2 terminals on the consult plug, As you look at it there are 2 rows of seven terminals (It is not the same setup as the ZD30) With the ignition ON but not started, grab a length of wire and bridge the 2 terminals on the bottom left (see my rough guide below) Birdge for 3 seconds then remove and the light should start to flash, Repeat the same procedure to erase the code and remove the light till the problem comes back.
1111111
BB11111
The light will flash slowly then a break then faster flashes, so 2 slow flashes followed by 3 quick flashes would be 23 which is accell pos switch (which seems to be a common fault related to cruise control)
These are a list of the fault codes from my manual, I have these printed in the car all the time just in case.
NUMERICAL INDEX FOR DTC
11 CAM POS SEN (PUMP)
12 MAS AIR FLOW SEN
13 COOLANT TEMP SEN
14 VEHICLE SPEED SEN
15 CONT SLEEV POS SEN
17 ADJUST RESISTOR
18 F/INJ F/B 2
21 F/INJ TIMG F/B
22 F/INJ F/B
23 ACCEL POS SW (F/C)
25 ELECTRIC GOV
27 ECM 1
28 OVER HEAT
31 ECM 2
33 *1 I/C INT/A TEMP SEN
34 NEEDLE LIFT SEN
36 FUEL CUT S/V 1
37 FCV SHORT
38 FUEL CUT S/V 2
42 FUEL TEMP SENSOR
43 ACCEL POS SENSOR
47 CRANK POS SEN (TDC)
48 GOV CUT CIRCUIT
55 NO SELF DIAGNOSTIC FAILURE INDICATED
141 - 148 X NATS MALFUNCTION EL section*2
branje napak in kode Patrol Y61 2.8TD
Po forumu brska: 0 registriranih uporabnikov in 104 gosti
